Who Wants a MSD Replacement for the Opticrap?
Old Mar 11, 2003 | 06:44 PM
  #136
93ZM6Tally's Avatar
Originally posted by Injuneer
One of the problems of producing a replacement distributor for the LT1 is the fact that no matter what you do, as long as you use the stock PCM to manage the engine, you need the low resolution pulse from the Opti. Without that signal, the PCM can not fire the injectors and shuts down the fuel system.
Go to the MSD website and look at their new "CPC" ignition system... possible to run 8 direct fire coils, with a standalone timing computer. Problem is, the CPC system needs a crank and cam position signal. It gets this by replacing a conventional distributor with a "plug"... essentially a replacement for the shaft of the original distributor with a cam postion sensor in it. What you need to convince MSD to do is to make a "plug" for the LT1 that can be inserted through a hole drilled in the back of the intake, and would have to provide a cam sensor signal that could be translated into the low res pulse for the Opti.... something I don't think would be that hard to do.
Fred
94 Formula A3: 381/TH400/N2O
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
What Fred said
Old Mar 11, 2003 | 07:02 PM
  #137
CamaroBoy96Z28's Avatar
An 8 coil ignition would be much better. But ANYTHING to ditch the opti-crap. I'm game.
Old Mar 11, 2003 | 07:08 PM
  #138
turbo_Z's Avatar
as long as you dont...
1. powerwash your motor
2. allow coolant to leak on the opti
you will have little to no problems with it.
now if you still convienced the opti is a POS for whatever reason then there is a few $700 options out there to take care of it.
Old Mar 11, 2003 | 07:39 PM
  #139
stonecoldz's Avatar
msd and hurst get on the ball, msd we need a good opti and waterproof and hurst we need that shifter four the a4
Old Mar 11, 2003 | 08:44 PM
  #140
JustAnotherGuy's Avatar
I would like to see one but i doubt i will
Old Mar 28, 2003 | 01:09 PM
  #141
Cam94Z28's Avatar
Count me in as well.
Old Mar 28, 2003 | 01:35 PM
  #142
rlax31's Avatar
i'm game
Old Mar 28, 2003 | 02:07 PM
  #143
95 Silver TA's Avatar
Count Me in if you dont have to spend over 500 bucks on it and it does work Better than stock and is (more reliable)....
Anything other than that would be kinda useless in my opinion, especially since you can replace vented opti for under 200 bucks each.
My 2 cents,
Claude
Old Mar 28, 2003 | 09:28 PM
  #144
n2oCamaro's Avatar
Originally posted by Josh-'97 WS6
Between LTCC and the Dynaspark opti, there is no reason to ever use a stock opti again, and no reason for MSD to get involved either.
At $600-$700, I think there is a reason for MSD to get involved. If just one guy (Bob with the LTCC) and a small company like Dynatech can come up with alternatives, why can't a large national company like MSD with all its resources and ignition exprience come out with a more cost effective option. Anyone who says there is not a demand for this needs to wake up. There are countless owners of Camaros/Firebirds, Impalas, Corvetts, Street Rods, S-10s, and anything else you can squeeze an LT1 into, out there that do not want to spend $600 on a distributor. Now don't get me wrong, I am glad there are people out there like Bob and Dynotech giving us alternatives, but $600 for a distributor
Old Mar 29, 2003 | 11:50 PM
  #145
Carlos01SS's Avatar
I'm definitely in.
This shouldn't have to be so hard.
Old Mar 30, 2003 | 12:57 AM
  #146
HM Murdock's Avatar
I have two 95 Z's in the household, and would GLADLY pay 450 for something that won't take a dump all the time with some mods.
Old Mar 30, 2003 | 01:00 AM
  #147
97SS0594's Avatar
count me in i dont feel like replacing one every 25000 miles. plus something w/ a little better spark wont hurt either!!!
Old Apr 18, 2003 | 10:32 AM
  #148
ScottZ's Avatar
Thanks for keeping this thread alive. Keep the posts coming. It is still alive, and the project is not forgotten.
Thanks.
Old Apr 18, 2003 | 10:39 AM
  #149
Something has to be done. There is such a HUGE following for an opti replacement. I hate my opti and I like reassurance that my car is as solid as it can be. build a replacement, this is a gold mine.
Old Apr 18, 2003 | 10:43 AM
  #150
Brettinator's Avatar
hell yeah why not, they build ignition systems for most all the old muscle why not an engine one step below the LS1...only makes sense, I think the market would be great with all the OPTI problems out there.
