who makes the biggest intake elbow?
Old Nov 17, 2007 | 10:19 PM
lt1rx798's Avatar
i have a 58 mm TB and a 3 1/2in MAS, and the trickflow i have is too small.
what are you useing?
Old Nov 17, 2007 | 10:35 PM
speed_demon24's Avatar
1le
Old Nov 18, 2007 | 12:07 AM
kylersaulsbury's Avatar
wanna sell your trick flow?
Old Nov 18, 2007 | 04:02 AM
lt1rx798's Avatar
i will once i get the bigger one. i bought it from another member who cut it a couple inches shorter.
it will have to work until i come up with a better option.
Old Nov 18, 2007 | 05:41 PM
ABA383's Avatar
The 1LE is probably the best way to go with the 58mm...I've seen countless threads on here about the metal ones being a restriction and I've seen the photos...I don't think the 1LE is hurting my mph at all and its a good fitting factory piece...
--Alan
Old Nov 18, 2007 | 06:52 PM
--Alan
My trickflow elbow could fit inside of my 1le elbow
Old Nov 18, 2007 | 08:32 PM
lt1rx798's Avatar
.....really? so the le1 is bigger than the factory piece?
Old Nov 18, 2007 | 08:40 PM
No its the same size as stock, but if your replacing a metal one you might as well get the 1le over the stock one.
Old Nov 19, 2007 | 02:34 PM
Vicious95Z28's Avatar
Did any of you guys ever see the one issue of GMHTP from a few years back when they made there own elbow and intake. If I remember correctly they used a 4" exhaust 90* and ovaled one end and used a silicone connector for the other. It was a near perfect fit to the throttle body. Just a thought
Old Nov 19, 2007 | 09:38 PM
Lisa33's Avatar
We used a 3" 90* pipe and cutted it in 2 pieces
http://home.koping.net/u3243a/images...s/DSC01582.JPG
Old Nov 20, 2007 | 09:51 AM
lt1rx798's Avatar
i though about that. that will more than likely be what i use. i was hoping for a purpose built one that was a little thicker for the sake of heat.
Old Nov 20, 2007 | 10:42 AM
You could always have it coated.
Old Nov 20, 2007 | 10:43 AM
looks pretty good. I'd actually like to see some specifics of what you guys did.
Old Nov 23, 2007 | 10:26 PM
x2
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
Maverlck32
Aug 19, 2002 11:45 AM
30thZ286speed
Aug 3, 2002 04:54 AM
