Who do i order the Racetronix Fuel Pump Kit
well ordered the pump today
Ill post results when i am done with the install.
BTW will i have to mess with the fuel pressure regulator, or should it all still be set like it was? (43psi)
Ill post results when i am done with the install. BTW will i have to mess with the fuel pressure regulator, or should it all still be set like it was? (43psi)
