white smoke......help
Old Mar 6, 2009 | 12:15 AM
Angel_G_Z28's Avatar
i raced some gti last week won and on the second run i had white smoke dumping through the cutout like crazy, any ideas on what it is? my guess is blown head gasket
Old Mar 6, 2009 | 01:24 AM
93FIRETURD's Avatar
yup that is a likely source check your coolant levels and check to see if your coolant bubbles when the car is running thos will help you determine if the headgasket did in fact blow good luck.
Old Mar 6, 2009 | 05:25 PM
i ckecked it after driving and yes the coolant was low, i havent checked the coolant while the car is running, you said if it bubbles then the gasket is blown right ?
Old Mar 7, 2009 | 02:31 AM
93FIRETURD's Avatar
That doesn't guaruntee that it is the problem but it is a very good sign fill it up and watch for a constant bubbling.
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
