While replacing the Optispark...
Old Aug 23, 2007 | 09:06 PM
Harvey's Avatar
Question While replacing the Optispark...
I took the old one off and when I turned it upside down, with the harness connection facing the ground, oil started coming out of that connection. I was just wondering if this is normal for a trashed Optispark or is there something else wrong with the car and the one I just put on going to do the same thing?
I'm sure the old one was trash because the car runs better now, but I just wanted to see if anyone had this same issue and wanted to know what caused oil to be in that section of the Opti.
Old Aug 23, 2007 | 10:29 PM
Stl94LT1's Avatar
Sounds like you needed to change the timing cover seals.
Old Aug 24, 2007 | 05:54 AM
Harvey's Avatar
Well, I did change the Optispark seal out. I didn't mess with the water pump seal. It wasn't leaking to my knowledge.
Old Aug 24, 2007 | 10:32 AM
mrseven's Avatar
When my crank seal went out, it started slinging oil up into the opti. Didn't cause a miss before I caught it, but I replaced it anyways.
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
