wheres the temp. sensor for fans on a 94 Formula
Old Aug 27, 2004 | 04:00 PM
Rice Killer87's Avatar
my friends car is overheating alot and im trying to wire the fans to run all the time. i need some1 to tell me where the sensor is that turns them on so i can wire it up b/c im not an LT1 guy.
thanks!
Old Aug 27, 2004 | 04:15 PM
Re: wheres the temp. sensor for fans on a 94 Formula
The sensor does not control the fans, the computer does. The computer uses the sensor in the water pump to get it's temp readings. Do a search for "fan switch" and you should have info you need for turnning on the fans.
Biggiebound
Apr 23, 2015 08:50 AM
HCz28
Feb 15, 2015 03:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
