Where is fuel pump fues? (Changen fuel filter)
Old May 8, 2006 | 08:06 PM
Jazsun's Avatar
I want to change my fuel filter but not get pissed all over, is there a fuel pump fuse I can pull and run all the gas out.
Old May 8, 2006 | 08:21 PM
n2ceptor's Avatar
Re: Where is fuel pump fues? (Changen fuel filter)
When you jack up the car, just disconnect the fuel pump electrical connection, by the gas tank, and start the car until it engines stops... Most of the pressure is gone then....
Change filter, reconnect connection, cycle ignition switch 3 times before starting to prime the fuel system.... You should be able to hear the pump priming...
Old May 8, 2006 | 10:18 PM
evilundisguised's Avatar
There's a Schrader valve at the back of the intake manifold on the fuel rail crossover that you can bleed fuel pressure off through. This way you only **** fuel all over the underside of your cowl, hands, manifold, and back of the engine. Use a rag over top of it to contain most of the spray. You can do like n2ceptor said and run it dry, but I doubt it'll completely bleed off all pressure before the engine dies.
Old May 8, 2006 | 10:45 PM
4th Gen LT1 F-body Fuel Filter Replacement
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
