Which dampner?
Old May 8, 2006 | 09:47 AM
94_camm's Avatar
Which dampner?
Which Dampner should i use for my 383 stroker?
Old May 8, 2006 | 10:57 AM
94EvilZ28's Avatar
Re: Which dampner?
if its internally balanced, why dont you use your stock one?
Old May 8, 2006 | 11:10 AM
atljar's Avatar
Re: Which dampner?
What type of balance are you running, how much HP, and how much RPM? Do you want underdrive, standard?
Old May 8, 2006 | 11:11 AM
playa7970's Avatar
Re: Which dampner?
you can use your stock one but the only problem that i had with my 383 stocker was that my crank had 2 keys on it so Chad from golen told me to chizel the first one out the shave a notch on the stock hub it self
Old May 8, 2006 | 12:54 PM
94_camm's Avatar
Re: Which dampner?
its internal balanced n iam lookin to get 450 hp.so should i just go for the stocker
Old May 8, 2006 | 01:56 PM
Re: Which dampner?
A 12-year old damper might be on its last legs.... we're starting to see more frequent problems with the rubber cracking. So it might not be a good idea to reuse an old one on a new engine.
You could get a new stocker, I think Pioneer also makes one for the LT1, ASP makes an integrated U/D pulley/damper. If you plan to run under 11.00 NHRA requires that you have an SFI-rated damper. ATI and Fluidampr make those, at about $400 a pop. Two schools of thought... either ATI sucks or Fluidampr sucks, depending on which engine builder you are talking to. I run the ATI. There is also a "Fluid Damper" (note the spelling difference) sold on eBay for about 1/2 of what a real Fluidampr sells for.... who knows how good the quality is though?
You can have the stock hub keyed..... a "must" with a blower and a good idea for any high HP application. The ATI and Fluidamprs are keyed.
Old May 8, 2006 | 10:49 PM
atljar's Avatar
Re: Which dampner?
For 450 hp and moderate RPM i would go with the ASP replacement underdrive setup. Its in the mid $100 range.
lt1srule
Aug 14, 2005 07:52 AM
blackz97
Apr 23, 2005 07:54 AM
Sweetred95ta
Apr 19, 2005 05:57 PM
Abdullah
Apr 8, 2003 08:08 PM
MSM69Z28
Mar 16, 2003 06:55 PM
