where does the fuel pump suck gas from?
Old Feb 26, 2004 | 02:46 PM
sabre81's Avatar
im wondering because i think i have bad/low octane gas in my tank. Im wondering if i should run the tank to almost empty then fill it with good ol 93, or if my normal fills from half a tank will eventually filter out the bad/low octane gas.
thanks
Old Feb 26, 2004 | 03:07 PM
Just add some higher octane fuel. The pump pulls off the bottom, and with the "recirculation" system, the contents become thoroughly mixed very quickly.
Old Feb 26, 2004 | 03:15 PM
BUBBA's Avatar
Why do you think you have bad/low octane fuel?
Did you fill it with low octane?
Does your car knock?
If your car doesn't knock because of low octane, just keep topping it off with high octane.
Hell, why not throw in 5 gal. of racing fuel?
If it doesn't knock, don't worry about it.
I use high octane with methanol. Some of the cheaper fuels are not worth buying because they don't have the good additives, like mentanol and although you might save on gas, you will probably get lousy mileage and shorter engine longevity in addition to lower power. JMHO
Old Feb 26, 2004 | 05:22 PM
sabre81's Avatar
well i logged a drive with freescan and got knock retard up to almost 13 deg. so i think between the new better gas and the lt4 km i put i, it has been running better.
Old Feb 26, 2004 | 05:31 PM
rpm4lalo's Avatar
I remember looking through LT1 Edit and seeing a "low octane retard"
The pcm would retard the timing when a low octane gas caused knock.
I have mine set to something like 8 degrees as the max the pcm will retard the timing if i accidently put in something lower than 93 octane.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
