Where do people go wrong when cleaning maf?
Old Aug 3, 2009 | 06:02 AM
corkss's Avatar
I'm gonna attempt to clean my maf sometime soon. I'de like to know where people go wrong when they clean it? So i can avoid damaging mine.
I searched how to clean it..but never really found an answer to what breaks or gets damaged?
Thanks in advance.
Old Aug 3, 2009 | 06:08 AM
SnakeOiler's Avatar
I'm not really sure where others go wrong.
All I ever do is spray electrical cleaner on on the wires.
Old Aug 3, 2009 | 06:38 AM
corkss's Avatar
ok...do you disassemble it as well...(the 4 torx screws)
thanks a lot!
Old Aug 3, 2009 | 06:49 AM
Mikes 1994 z28's Avatar
I just sprayed mine with intake cleaner.
Old Aug 3, 2009 | 07:15 AM
Use only a cleaner intended for an MAF sensor. CRC makes one. Follow the instructions on the can.
Old Aug 3, 2009 | 11:25 AM
Z28SORR's Avatar
It's normally the small, very thin sensor wire that gets damaged or broken. Using the wrong cleaner can "coat" the wire and cause sensor reading errors.
Old Aug 3, 2009 | 01:15 PM
n2ceptor's Avatar
Never use carb or brake cleaner.......
Old Aug 3, 2009 | 04:26 PM
corkss's Avatar
WOW!! thanks for the info guys..i now feel confident enough not to break something....lol...knock on wood!
Old Aug 3, 2009 | 07:30 PM
ulakovic22's Avatar
No need to take it apart, but you can if you want to. Leave the screen intact as well, just clean it. Always use electric contact cleaner like Fred said, I have CRC as well, they sell in O'Reilly's. Don't try to touch or wipe anything down inside by the wires cause you take the chance of breaking them.
Old Aug 5, 2009 | 02:38 PM
corkss's Avatar
Jus wanna say thanks guys. I sprayed my maf out this morning and went for a morning cruise...My hesitation went away when accelerating!!!! Night and day!!! Thanks a lot!!
Old Aug 7, 2009 | 09:37 AM
Sick97SS's Avatar
I cleaned mine with some electronics cleaners and Q-tips a few months ago. And it made a HUGE difference in engine smoothness.
Old Aug 30, 2010 | 12:09 AM
AZZKKER's Avatar
on a side note, what should the normal maf reading be for a 95 z28 with lingenfelter CAI and headers, everything else stock? a custmer of mine has a major lack of power and wonder if this could be the problem. its a stock sensor that has been descreened before he bought the car. all other redings look fine on the scanner but the maf gm/s read a top of 167 gms/s at wot and that is at the top of the rpm band. this car just feels slower then all the other ones i have driven. thanks in advance
anthony
DirtyDaveW
Dec 1, 2016 05:37 PM
lt1matt
Mar 21, 2015 07:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
