where do I install fuel pressure sender unit?
Old Jan 1, 2006 | 07:32 PM
hellostop's Avatar
Is there a place in fuel rail to install? It has about the same threads as oil pressure type sender.
Old Jan 1, 2006 | 07:39 PM
OBE1 95Z28's Avatar
Re: where do I install fuel pressure sender unit?
Always helps to know what year car you have On a 95 - 97 you install it to the Schrader valve located on the back of the fuel rail. You'll need a 90 degree adapter and be sure to remove the check valve located inside the Schrader valve (works like a tire stem valve).
Old Jan 1, 2006 | 07:42 PM
OBE1 95Z28's Avatar
Here's a photo from Shoebox's site:
http://shbox.com/1/fp_reg.jpg
Old Jan 1, 2006 | 10:02 PM
hellostop's Avatar
Thanks!
Old Jan 1, 2006 | 11:09 PM
94-97 are all the same... only the 93 is different on location of the Schrader valve.
Your fuel pressure sending unit will typically have a 1/8" NPT male connection on it. The Schrader valve has a -4An connection. Best way to connect is to get an NOS #17535 -4AN 90-deg swivel elbow. That gets the connection pointed away from the cowl, and allows you to "aim" the connection any way you want it. If you try that with a non-swivel fitting, you will probably nd up overtightening the connection and possible damaging the Schrader connection.
Also a good idea not to mount the sender directly to the Schrader connections.... the sender doesn't need the engine vibrations, and the hard line doesn't need the extra weight on the Schrader connection. Run a short length of braided SS hose, -4AN to connect to the NOS fitting, and 1/8" NPT on the other end to allow you to use a common 1/8" NPT coupling to connect the sender to the hose. This way you can tuck the sender out of the way, like behind the PCM. You can find the braided SS hoses on eBay for reasonable prices.
The NOS fitting is on the Schrader valve in this photo:
Old Jan 4, 2006 | 04:15 AM
camaronutt's Avatar
Just installed mine tonight!! I followed an older post about this that Injuneer had wrote in. All the part numbers and everything was right on. Install went very smoothly. Thanks INJUNEER, Your the man
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
