Where do I find a 1LE intake elbow ?
Old Apr 13, 2005 | 02:40 PM
ZPower_123's Avatar
I phoned my local chevey dealer for a 1LE intake elbow for my 94 Z28
thay said it was $300!!! WTF? jegs has a vortec aluminum elbow for $75
Does anyone know where i can get a cheaper 1LE elbow or should i just get the vortec one ?
Old Apr 13, 2005 | 02:48 PM
Pasky's Avatar
Re: Where do I find a 1LE intake elbow ?
Call them again, ask them for the part number, than order it from gmpartsdirect.com
You'll save over $230. Dealer mark up is usually 300%.
Old Apr 13, 2005 | 03:23 PM
DavesLT1's Avatar
I've seen them on Ebay for $50-$70. I got lucky and found one in a junkyard for $10.
Old Apr 13, 2005 | 03:29 PM
Owens Racing™'s Avatar
From my understanding the only difference between the two is the air silecing tube. I removed this plastic tube and used a peice of rubber cut in an ovel to fit the hole left by the silencer and used The Right Stuff sealant and smoothed it out on the inside. A little water(spit) lets your finger glide over this stuff and make a smooth plug if you will. IMO on the Aluminum peice it can get heat soaked and cause a HP loss not much but hey a little adds up.
Old Apr 13, 2005 | 04:00 PM
J96Z's Avatar
Don't waste your money on a 1LE elbow, unless your stock one is ripped or something. Just plug the hole in yours and abracadabra, you have yourself a 1LE elbow and your wallet is still the same weight. Use a piece of 2x4 wood and cut out the size of the plug and hose clamp it in. You could even paint the wood black if you'd like, like I did. You know anyone with a jigsaw or bandsaw?
Old Apr 13, 2005 | 04:09 PM
1-bad-z28's Avatar
either that or get one of those nice polished vortech or trick flow. They are like $80-$90
Old Apr 13, 2005 | 04:12 PM
J96Z's Avatar
I have the trick flow one and it bolted on with my K&N intake with no problems. I hear that sometimes that the vortech one will have to be cut to work, but I have no experience with it.
Old Apr 13, 2005 | 04:16 PM
1-bad-z28's Avatar
why would it have to be cut? It comes with the rubber connection things that hold it to the maf and the tb.
Old Apr 13, 2005 | 10:24 PM
ZROCKD's Avatar
The Vortech elbow is too long to be installed with the SLP CAI. At least that was my experience. Had to measure, tape a cut line, then had the local muffler shop saw cut to fit.
Old Apr 14, 2005 | 09:14 AM
Jps 1LE's Avatar
Dude, call Jason Cromer and order a 1LE elbow for like $45. I believe the part number is 25147210. He'll give you a good deal and wicked low shipping costs. Look on shoebox's sight to verify http://shbox.com/1/4th_gen_tech1.html. Good luck with the purchases
Old Apr 14, 2005 | 10:08 AM
CamaroBoy96Z28's Avatar
I second that. Jason is THE best to deal with when going with GM parts and my only choice. I used to have a 1LE but have a Trickflow now, I'm just tired of rubber tearing on the lip by the TB.
Old Apr 14, 2005 | 11:30 AM
SlickBlack Z's Avatar
I have a 1LE elbow in great shape i can sell you if you are interested. Lets say...$40? Let me know. (filomath@hotmail.com)
Old Apr 16, 2005 | 06:02 AM
BlueCamaroZ28's Avatar
Here, summit racing has it for $59.88.
http://store.summitracing.com/partde...=KeywordSearch
FormulaV8
Sep 1, 2002 03:44 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
ferraricameron
Jul 29, 2002 07:46 PM
