Where can I pull 12V+ Ignition Switched power????
Old Jun 22, 2003 | 03:43 PM
96 WS6's Avatar
It's for a 5" tach.
Old Jun 22, 2003 | 04:30 PM
Blue89Bird's Avatar
fuse box
Old Jun 22, 2003 | 04:34 PM
GreenZ28in503's Avatar
I pulled power from the ignition-on wire for my stereo. No problems since the deck draws the majority of its power from the always-hot wire.
Old Jun 22, 2003 | 04:48 PM
96 WS6's Avatar
Okay can somebody tell me a location and color of the wire??
Old Jun 22, 2003 | 05:13 PM
scoobysnax83's Avatar
Any wire (before fuse) in the fuse box under the hood. The big red one is the hot lead.
Old Jun 22, 2003 | 07:07 PM
SubsAnDubs's Avatar
Check out this link to brent frankers page. This is for an alarm install, but scroll down and there is a picture of the back of the fust block. There is arrows pointing to the switched power off the block.
http://www.bfranker.badz28.com/fbody/alarm96up2.htm
Good luck
Old Jun 23, 2003 | 01:13 AM
There is a spade lug in the fuse panel at the end of the dash marked "IGN".... that is "switched" +12V power. Here's where it is on my 94. There is a spade connector crimped onto the orange wire. Just push it into the fuse panel. 96's may be a little different... I know some of the fuses are in different locations.
Old Jun 24, 2003 | 01:08 AM
96 WS6's Avatar
I have the wire ready to hook up except it's in the engine bay... which wire should I tap for the 12v switched power in the underhood fuse box???
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
