Where can I pull 12V+ Ignition Switched power????
Check out this link to brent frankers page. This is for an alarm install, but scroll down and there is a picture of the back of the fust block. There is arrows pointing to the switched power off the block.
http://www.bfranker.badz28.com/fbody/alarm96up2.htm
Good luck
Good luck
There is a spade lug in the fuse panel at the end of the dash marked "IGN".... that is "switched" +12V power. Here's where it is on my 94. There is a spade connector crimped onto the orange wire. Just push it into the fuse panel. 96's may be a little different... I know some of the fuses are in different locations.
Jan 23, 2015 01:13 PM
