Where can I find a bolt/rod to install crank hub.
I've tried Home Depot, Autozone, NAPA, and Advance Auto Parts. Nobody carries a 7/16 x 20 threaded rod or bolt so I can install my crank hub! Looks like I may be shelling out the $30 for the Snap-On tool.
Try to find a industrial fastener store in your area. They have all the grade 8 stuff in just about every size and length. Call a couple of the industrial tool houses in your area (places that sell BIG tools) they should be able to tell you were one is at.
Jeff D.
Jeff D.
PoorMan,
I called a few places that sell undustrial stuff and even they said that 7/16 with a fine thread is not a popular size. I did find some grade 2 stuff at NAPA, but I'm questioning weather it will be strong enough.
Any body have the name of a national chain that would sell something like that? I'd feel much safer with a grade 8 piece.
Ziegler Nut and Bolt down here in Canton might have what you are looking for. Its a large warehouse that sells nothing but nuts, bolts and threaded rods. Come to think of it, thats where I got my threaded rod when I did my heads and cam. I don't know what grade the rod was but it was enough to get the crank hub on.
Ziegler's Bolt & Nut House
330-478-0874
I already called and asked and they do have 7/16 x 20 threaded rods. The strongest grade is 11.51$ for 3 feet.
You can call and order it if you don't know where it is (its a hard place to find) or I can pick one up for you and just meet me at Summit Racing's parking lot since I have to go up there either today or tomorrow after work. The choice is yours.
Waswa
330-478-0874
Waswa
Thanks Waswa
I work in Hudson so I'm just gonna drive down there on my lunch break. They told you $12? They told me $5, but that was for grade 8, I wasn't aware of anything stronger.
As a side note, a rubber head mallet can put the hub on. Just hit the hub, dead center, with several small taps. You'll probably be going at it for a good 5 minutes, but it will get it on deep enough to where you can use the real bolt to finish it off.
1LEThumper
Jul 14, 2003 12:45 PM
