Where to buy a scanner for my 95z
Old Jun 10, 2007 | 11:54 AM
tman78's Avatar
I am wanting to get a trouble code scanner for my 95z and i couldnt really find one, if anyone could tell me where to get one. thanks
Old Jun 10, 2007 | 06:09 PM
NovaTodd's Avatar
I got mine at the local Kragen. It is made by Auto X Ray - make sure you get the one that can read OBD1 AND OBD2.
94 & 95 used a OBD1 computer with an OBD2 type connector - but just jumping the pins will not work (as it did with older cars).
Old Jun 10, 2007 | 08:39 PM
bacatrane's Avatar
Here ya go bud
http://www.maxtool.com/index/st_autotools.asp
I bought mine from them and recieved it quickley.
You do have to call Auto X ray and ask to buy the OBD2 connector, it's only 15 bucks and the info is included in the booklet you get with the reader.
Old Jun 11, 2007 | 10:13 AM
Only the 1995 F-Bodys use the 16-pin OBD-II style connetor with the OBD-I PCM. The 1994 F-Body LT1's use a conventional 12-pin OBD-I ALDL connector.
If all you need is an OBD-I tool, consider a used Auto X-ray OBD-I scanner, typically available for less than $100. Or, get free scanning/data logging software and a cable ($50-100) for your laptop.
Old Jun 11, 2007 | 01:33 PM
tman78's Avatar
Where could i get the free scanning/data logging sofware and cable for my labtop. Thanks
Old Jun 11, 2007 | 01:39 PM
JAB's Avatar
JAB
www.akmcables.com for a cable.
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx for scanning.
That would get you a basic start.
Old Jun 11, 2007 | 01:40 PM
tman78's Avatar
thanks man.
Old Jun 11, 2007 | 05:44 PM
or....
http://www.ttspowersystems.com/
After 20 uses, it will ask you to license the copy.
Old Jun 11, 2007 | 06:58 PM
tman78's Avatar
Thanks i think ill do that, thanks to all you guys that helped.
Old Jun 11, 2007 | 07:23 PM
JAB's Avatar
JAB
Originally Posted by Injuneer
or....
I couldn't remember what that thing was called or I would have linked it too.
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
KYWes
May 22, 2015 08:48 PM
aj2494
Mar 12, 2015 10:17 PM
