Where to buy A/c delete pulley.
Re: Where to buy A/c delete pulley.
Part # 10115875
Might want to try www.gmpartsdirect.com.....but you'll pay a good chunk for shipping.
No gain other than weight savings, if you need it quick go to your dealer and they can get one quick. If you have a working ac do not do it, its not worth your ac at all. Trust me, I have this pulley because my ac is messed up.
Is the A/C delete pulley (GM p/n 10115875) as listed on shoebox's website the same as the 1le ac delete bracket and pulley as advertised on ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I was gonna order this from GM parts direct but just wanna make sure Im getting the bracket as well as the pulley. I would assume they are the same except the price quoted on ebay is substantially more.....Any ideas?
Yes, it should all come together. I called the local dealership with that part number, and you get the pulley with that bracket as one "piece."
I just installed my pulley this past weekend. Use the same bolts for the compressor when you install the pulley.
Getting that compressor out was a hassle for me. I rounded off one of the bolts on the back of the compressor and had to Dremel the coolant lines in 3 places so I could pull the whole thing out.
Getting all that crap out is nice, though. I now have easier access to plugs 2 and 4 from underneath...
...and I can use the same belt too. Some people have had to use a different belt b/c the A/C delete pulley is smaller than the compressor's. Make sure yours isn't loose.
Good luck.
Good luck.
racecarz28
Mar 30, 2015 09:55 PM
