When to upgrade 24# injectors?
Old Jul 24, 2003 | 02:27 PM
ZDriver96's Avatar
My z28 puts 330 hp to the ground and 340 ft lbs of torque to the ground.
Im curious at what duty cycle my injectors would be running with this much.
Im fairly sure i should upgrade to some 30#'s.
Whats everyones experience on this.?
Old Jul 24, 2003 | 02:28 PM
madwolf's Avatar
Most people will probably say that the stock injectors should still be enough for these numbers, but I would personally upgrade to some 30s.
Old Jul 24, 2003 | 02:33 PM
You might want to search for a current thread on 30# injectors that has a lot of info on injector sizing. By my calcs, you're at 384 flywheelHP, and the 24's are barely adequate (they are actually 24.9). They are pushing 90% duty cycle, so IMHO it might be time to look at larger injectors, or to bump up the fuel pressure.
Seems to be a lot of differeing opinions on this... people are actually recommending 98% duty cycle, and 450 flywheel on 24's.
Old Jul 24, 2003 | 04:48 PM
Camaro_Maniac63's Avatar
I would go ahead and get them. They might not help too much, but they definitely will not hurt. I am doing the upgrade soon too.
Old Jul 24, 2003 | 04:58 PM
Z95m6's Avatar
i have heard that the 24's are put to there limits even with yhe little hot cam.
Old Jul 24, 2003 | 11:46 PM
fireman's Avatar
I recently put down 350rwhp with 24lb SVOs. I heard that even though they are still 24lb, the SVOs were good to a higher power level than the stock 24s.
Old Jul 24, 2003 | 11:52 PM
Carlos01SS's Avatar
Dude, I like your car.
What have you done to your engine? I would like to know, I'm planning on getting my LT1 built slowly but surely, factory injectors for 93's are 22's, I figure I'll keep those until I start working on the internals. I'm new at this...
Old Jul 25, 2003 | 08:06 AM
pu12en12g's Avatar
Great thread about this:
http://web.camaross.com/forums/showt...threadid=37904
MichiganSkip
Aug 31, 2002 08:52 PM
MichiganSkip
Aug 16, 2002 08:17 PM
MichiganSkip
Aug 16, 2002 08:09 PM
MichiganSkip
Aug 12, 2002 03:51 PM
derty
Jul 16, 2002 12:20 PM
