When should i repack my wheel bearings?
Old Apr 21, 2003 | 02:12 PM
97firechicken's Avatar
Basically the subject line question. I have 75,000 miles, i think its time, but what do yall think?
Old Apr 21, 2003 | 02:21 PM
philcam01's Avatar
you don't have wheel bearings are cars use hubs
Old Apr 21, 2003 | 02:26 PM
96CamZ's Avatar
One of mine just went bad. I have just under 77k on the clock. It cost close to $130 for the hub assembly.
Old Apr 21, 2003 | 02:28 PM
twells's Avatar
like the other guys said, you must replace the whole hub assembly. it sucks and is expensive
thomas
Old Apr 21, 2003 | 02:40 PM
grendal's Avatar
thomas
Ditto. There ARE wheel bearings, they're just not serviceable. They're inside the sealed hub and you have to buy a complete new unit.
-Michael
Old Apr 21, 2003 | 02:45 PM
Aw damn that sucks bad, but i guess they are ok until the break?
Old Apr 21, 2003 | 02:52 PM
grendal's Avatar
I don't know if you'd really want to wait until they break as that tends to cause severe vehicle damage and possible death... heh..
You can do the usual bearing tests, jack the car and shake the wheels and check for excessive play..... Though generally they get really noisy before they break, so if they're really noisy that's a sign of needing replacement.
77k isn't much though... I wouldn't worry unless they're noisy.
-Michael
Old Apr 21, 2003 | 02:56 PM
96CamZ's Avatar
I only did the side that was bad, you will know if they are bad because there will be some play in the wheel. Jack the car up and get a hold of the wheel. If you can get movement out of the wheel (side to side) then you know the bearings are bad.
Also, you should get it aligned after you replace the hub(s).
Old Apr 21, 2003 | 02:57 PM
All_Z_Way's Avatar
I broke a hub at Texas World Speedway road course while doing over 100mph. Luckily I got slowed down with no damage.
It felt and souded just like a blown tire and the tread coming off the tire.
In reality it was just the wheel moving all around on the hub without any bearings.
Old Apr 21, 2003 | 02:59 PM
1fast95Z's Avatar
Front end alignment is not required. Not a bad idea if it's been awhile, but not necessary.
grabbem88
20
Dec 27, 2015 07:42 PM
akwa
Apr 5, 2015 05:09 PM
warmeck
Mar 8, 2015 08:01 PM
