When are shaft mount rockers necessary???
Old Feb 13, 2005 | 02:34 PM
texasTA's Avatar
I am trying to decide on if I need shaft mount rockers for my setup. Here is what I will be running:
fully forged Callies 383 setup
Stage 3 Jordon Musser ported LT4 heads/intake
58mm TB
Longtubes through true duals
solid roller Cam Motions Camshaft (nothing crazy but around .650 lift 240s/250s duration)
300-350 direct port NX setup
I have been told that 1.6 Pro Mags are fine and then I have also been told that I HAVE to run shaft mounts. So, if you state that I need the shaft mounts, please explain to me why I do.
THanks
Old Feb 13, 2005 | 02:45 PM
RE AND CHERYL's Avatar
Re: When are shaft mount rockers necessary???
It's mainly going to depend on your spring pressures and how hard you intend to run it. Whats your max RPM going to be?
Old Feb 13, 2005 | 08:37 PM
texasTA's Avatar
Well, I am going to be running it to 7000 RPMs and shifting at 7100 (since the factory tach is fast). I am not sure what the spring pressures are right off hand.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
