When do you lockup your TC?
Old Jun 20, 2003 | 05:06 AM
mastrdrver's Avatar
I was wondering if you can lock it up and drive around in traffic with it like this and then unlock it when you go racing? So you can run a big stall without having to deal with the high stall effects in traffic.
Jeremy
Old Jun 20, 2003 | 05:14 AM
GhostZ's Avatar
I'm not sure if you can use a lockup switch in a 4l60e like you can with other tranny's.
I have a 3200 stall and stop and go traffic isn't a problem. How high of a stall are you looking to go with?
Old Jun 20, 2003 | 05:23 AM
mastrdrver's Avatar
I was planning on building a stout 383 and was trying to decide if to put a manual or an auto behind it. I was thinking somewhere in the 3600-4400 stall range. I wanted to run as much stall as possible without have the ill effects of it.
Old Jun 20, 2003 | 05:46 AM
GhostZ's Avatar
If you're going that stout have you thought about looking into a turbo 350 or 400?
Of course the downside is not only weight, a little more power loss, expensive quality torque converters and a very expensive OD.
As I'm sure you know T56 swap would probably be more economical and, with a good clutch, could probably handle as much as you're going to want throw at it.
You're in the same boat as I am.....still undecided on which route I'm going to go with my tranny (which is on its last legs).
Old Jun 20, 2003 | 07:44 AM
TedH's Avatar
I have a3600 TCI and a lockup switch with my 700R4. I can only lock the converter in 4th gear. Works great for me as that is the only time I really need to lock it up.
Old Jun 20, 2003 | 10:45 AM
Derrick Redd's Avatar
I would say if you drove around with it locked all the time you would the converter. I lock mine up in 3rd gear only. 3,600 stall.
Old Jun 20, 2003 | 11:35 AM
KCFormula's Avatar
Jeremy- I thought you sold your car?
Old Jun 20, 2003 | 01:51 PM
mastrdrver's Avatar
I sold the car to my dad, but I'm looking looking for another and didnt know if I wanted an auto or manual.
95_lt1_z28
Aug 30, 2015 06:17 PM
dkeers
Nov 5, 2003 12:04 PM
Z28James
3rd Gen / L98 Engine Tech
Nov 4, 2003 07:24 PM
AutoRoc
10
Oct 14, 2003 08:02 PM
rskrause
Oct 9, 2003 08:57 PM
