When do the fans turn on?
Old Mar 31, 2004 | 08:12 PM
jdizzell's Avatar
I have notice that neither of my fans turn until I turn the a/c on. I let the car idle until the temp got almost to the red line and no fans were on. Then when I hit the a/c, both of them turned on. Whats up with that? Anyway to wire the fans up so that both turn on when I start the car?
Old Mar 31, 2004 | 08:24 PM
The pcm will command low speed fans "ON" at 226º and "OFF" at 221º and high speed fans "ON" at 235º and "OFF" at 230º.
If you have 2 fan relays, replace low and high speed with primary and secondary in the blurb above. I would not wire the fans on all the time. They are not needed all the time.
You might have a problem with the PCM seeing the correct temp to turn on the fans. A scan tool can verify what the PCM sees.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
