Wheel stud for weld rims
Old Mar 25, 2004 | 08:51 AM
bski224's Avatar
Im going with 15" welds and im going with longer studs, when i change studs i assume i gotta slide axle out of my 12 bolt correrct?? and get the ABS ring pressed of and on again, anybody that has done tis please reply Thanks
Old Mar 25, 2004 | 08:58 AM
badblackta's Avatar
just get centerline telstars. They fit on the stock wheel studs, use stock lug nuts, clear the brake calipers,tuck underneath the fenders, look good, what more could you want?
Old Mar 25, 2004 | 09:00 AM
bski224's Avatar
i have weld draglights already plus i like the way they look better, but regardless if i got the telstars id still have to change wheel studs to pass tech!!
Old Mar 25, 2004 | 09:05 AM
badblackta's Avatar
I get through tech fine with mine, because they take the acorn style lug nuts
Old Mar 25, 2004 | 09:07 AM
bski224's Avatar
what size tires you running. Any way the stock lugs are not that strong as aftermarket ones. Dont want one snapping on me when i do a 6,000 launch
Old Mar 25, 2004 | 09:19 AM
speedmiser's Avatar
I'm running a strange 12 bolt and you dont have to pull the axles to change the studs.
Im running the following screw in studs with 15x10 Weld Draglites
3" x 1/2"-20, MOR-46200
Damn straight, the stockers arent as strong
Old Mar 25, 2004 | 09:20 AM
badblackta's Avatar
well yeah I see where you are coming from. I am running 26x10.50.15 et streets
Old Mar 25, 2004 | 09:38 AM
bski224's Avatar
but with the scre in studs can you do that with the abs ring also, if so that would be great where did u but them
HarleyZ28
Oct 5, 2015 06:23 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
