Wheel hop......
Old Oct 22, 2003 | 12:34 PM
  #16
badassT/A's Avatar
I agree with RamAir95TA...BMR is great.
Old Oct 22, 2003 | 12:35 PM
  #17
Mir Hussain's Avatar
Question
Is it a POSI ? What kind (Band and kind)
If its Spool or Locks, then its normal.
Old Oct 22, 2003 | 12:45 PM
  #18
simple's Avatar
HD Eaton posi that Moser offers and it only seems to do it on right hand turns?
how much can the rear sway bar affect how the rear moves when turning?
Old Oct 22, 2003 | 02:28 PM
  #19
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Yeah my suspension parts are all BMR..........good product.
Chris
Old Oct 22, 2003 | 03:38 PM
  #20
FFingers79's Avatar
I got the LCA's through a group purchase for very cheap, and they have made a big difference. Fred
Old Oct 22, 2003 | 09:36 PM
  #21
If its Street/Pro version. Then it mean; its not working.
Old Oct 22, 2003 | 09:42 PM
  #22
12SCNDZ's Avatar
I've never had a wheel hop problem...Even though I've got a completely stock suspension with the exception of the front sway bar removal. The car pulls 1.67 60 ft. times and is yanking the drivers side front wheel a few inches off the ground.
Maybe it has something to do with the M/T ET Streets? But, I never had it with the Drag Radials, either.
Frank
Old Oct 22, 2003 | 09:50 PM
  #23
Exclamation
Really!!!!!!!!
You should have snaped the Rear end; like what happen to a tooth pick; if you step on it.
You are very lucker Person
Bravo to you
Old Oct 22, 2003 | 09:59 PM
  #24
S.J.S.'s Avatar
someone was saying it was due to the lowering kit.
Old Oct 22, 2003 | 10:08 PM
  #25
Arrow
Lowering Kit kills the weight Xfer!
Cause Wheel hopping or No traction!
Old Oct 22, 2003 | 10:10 PM
  #26
S.J.S.'s Avatar
will the LCA's fix it???
Old Oct 22, 2003 | 10:14 PM
  #27
I have BMR LCA, and relocation bracket Panrod
Old Oct 23, 2003 | 09:40 AM
  #28
simple's Avatar
then i should be able to tell if tis broken by laying down some rubber to see if both wheels are spinning?
thanks
Old Oct 23, 2003 | 10:03 AM
  #29
That would only prove its locking both wheels.
POSI unit also need to do some limited slip. Like when you turn; it should let it slip; without you feeling it. If its not letting it slip. Then it mean its LOCKEDUP like spool or lockers! Which another sign of BAD posi
Old Oct 23, 2003 | 01:14 PM
  #30
Depends on the posi unit... a heavy duty unit, like the one Strange sells with 800# preload is prone to "chatter" on turns. Isn't "bad"... its just a little too sensitive.
SJS:
A Moser 12-bolt is not necessarily a "posi".... you could also buy one with a locker or a spool. They would definitely be chirping the tires in turns, as Mir has pointed out.
simple:
Did you use the limited slip additive?
