Wheel hop......
Old Oct 21, 2003 | 11:54 AM
S.J.S.'s Avatar
Wheel hop......
Before I blew my motor I had some bad wheel hop. I never had it with my GSC's. When I moved to the 11" 315's on the rear I have a lot of hop now. What causes it and how do I get rid of it?
Old Oct 21, 2003 | 12:04 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Lower control arms, brackets and a torque arm will do the trick............its caused by bad suspension geometry fromt the factory, and its very bad for the rear end...... I had bad wheel hop till i put those on................no more wheel hop....
Chris
Old Oct 21, 2003 | 03:14 PM
TedH's Avatar
I solved mine with just an air bag on the right rear.
Old Oct 21, 2003 | 03:23 PM
Got-LT1's Avatar
Same here, works real good.
Old Oct 21, 2003 | 07:02 PM
S.J.S.'s Avatar
What are you talking about?????
Old Oct 21, 2003 | 07:32 PM
Got-LT1's Avatar
http://www.ls1speed.com/catagory.cfm...ory=suspension
look for airlift air bag set, it's just past halfway down.
Old Oct 21, 2003 | 08:46 PM
S.J.S.'s Avatar
Holy CRAP!! You guys were actually serious. I thought you both were messing with me. There actually is an airbag!! You keep them on the car all the time???
If I was to go with the lower control arm, torque arm and brackets....which ones should I get. Part #wise??
thanks
Old Oct 21, 2003 | 08:48 PM
RamAir95TA's Avatar
thanks
You really can't go wrong with BMR parts. They make everything you could want for suspension.
Old Oct 21, 2003 | 09:28 PM
S.J.S.'s Avatar
Do I really need to get all that just to get rid of wheel hop??? That's like $800.00. I just finished my motor and tranny...down about 9K.
Old Oct 21, 2003 | 09:33 PM
RamAir95TA's Avatar
LCAs alone should do the trick. A good set is about $120.
Old Oct 21, 2003 | 09:49 PM
BlakeW5's Avatar
Yeah, I never really had wheel hop, but new LCAs should clear it up. I bought Lakewood control arms, nice quality, works well ( I guess, I never had problems), and can be bought through Summit for right around $100 shipped.
Old Oct 22, 2003 | 10:27 AM
Mir Hussain's Avatar
Lightbulb
I had same problem.
I installed LCA, and Relocation braket; problem is gone. SOme Panrod can aid greatly on topoff these Mods!
Old Oct 22, 2003 | 10:42 AM
S.J.S.'s Avatar
Thanks MIR and everybody....thats exactly what I needed to know. Someone who had the problem. There ya go.
Old Oct 22, 2003 | 12:04 PM
simple's Avatar
what about wheel hop when making a turn, whats the culprit of that? i seem to have that problem when making a right hand turn
edit: this has only been happening after installed my Moser 12bolt, i went to the track about 2 weeks ago and didnt have any wheelhop issues in a straight line, just when turning
thanks
Old Oct 22, 2003 | 12:29 PM
S.J.S.'s Avatar
The Moser 12 bolt is a posi. I doubt the differential slips on the turn. Dunno if thats the correct term (someone help me on this). But because of that....when making a turn the inside wheel is actually turning less than the outside wheel. Thats where you get the hop. Its actually trying to like catch up I guess you could say.
