Wheel Bearings Accessible?
Old May 30, 2003 | 11:55 AM
All4Chevy's Avatar
I saw a post on here earlier that said you could not replace the wheel bearings in the f-bodies and you had to replace the entire hub for $130. The deluxe kit for my gear installation that I am buying on thunder racing's site says it comes with wheel bearings...are they possible to change or what is the reason of getting new ones.
Bill
Old May 30, 2003 | 12:15 PM
LWillmann's Avatar
The hub replacement is probably required for the front wheel bearings, the ones you are talking about are the rears.
Old May 30, 2003 | 12:27 PM
Brent94Z's Avatar
Super Moderator
Are you sure you are thinking about the correct bearings? I bought a pro/complete/whatever install kit too and it came with the axle bearings for in the rear gear housing but not the bearings that go out by the wheels. If yours in fact do, let me know! Thanks!
Old May 30, 2003 | 03:08 PM
All4Chevy's Avatar
This is what thunder racings website description of the kit is:
Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. (All of the small parts and pieces necessary to RESTORE an axle to like new condition!)
So I figured those were the bearings to go in for the rear wheels.
carguy0119
Apr 11, 2016 11:11 PM
grabbem88
20
Dec 27, 2015 07:42 PM
akwa
Apr 5, 2015 05:09 PM
warmeck
Mar 8, 2015 08:01 PM
