Whats wrong with this car? Vid
Old Nov 24, 2008 | 08:57 AM
  #16
Jditlfm's Avatar
how is the valve adjustment? too tight? Spark plug wires?
Old Nov 24, 2008 | 03:30 PM
  #17
mdacton's Avatar
wires plugs opti are all new now, coil checks out good. Valve adjustment is good, I have 5/8 preload
I do not think it is anything mechanical, it has to be an electronic problem or a sensor or somethign.....
Still have not logged it...... I do not have the cable for this car and having a hard time trying to get it.
Old Nov 25, 2008 | 02:52 PM
  #18
mdacton's Avatar
May have found the problem....
could the spees sensor have been making the converter lock up when it shifted into 3rd?
I fixed the knock sensor tried it...same thing
unplugged the speed sensor and it seems to not do it now....
Old Nov 25, 2008 | 03:57 PM
  #19
WS6T3RROR's Avatar
Sure could. Poor programming could also be the issue (seen it before). I would think you'd see a problem on the speedo though if something was wrong with the sensor.
Old Nov 26, 2008 | 04:33 PM
  #20
sn8ke eatr's Avatar
could be lack of driver mod
Old Nov 29, 2008 | 07:41 PM
  #21
bubba4's Avatar
Try disconnecting the knock sensor wire and series it to a 4k/.25 watt resistor to gound.
It will bypass the knock sensor in the computer. (This will rule out the timing retard).
Old Nov 29, 2008 | 08:32 PM
  #22
mdacton's Avatar
I did that with a 3.9k
drove it today, ran the exact same time and exact......265 3 passes in a row like is has a governer on it. I'm done working on it...I do engines not tuning. I think its a tuning problem....the motor didn't blow up so its someone elses turn to work on it.
Personally I think it was always in the tune, the person I had tune it gives me BS excuses, will not return calls or emails.....I recomend never using them and only deal locally. That way you don't get ****ed so bad..... pretty much I just wasted that money and he is in no way willing to help or stand behind what he does.
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
