Whats the safest way to turn the crankshaft??
Old Nov 5, 2003 | 03:44 AM
96 WS6's Avatar
If I'm trying to turn it to put each cylinder at TDC for some valvetrain work... I don't like the idea of using a breaker bar on the crank pulley bolts, I don't like stripping bolts, it's like nails on the chalkboard. Any other way to do it that's a little safer???
Old Nov 5, 2003 | 07:55 AM
Fastbird93's Avatar
Don't use the crank pulley bolts. Use a 5/8 standard socket and ratchet/breaker bar. You put the 5/8 socket in the center of the crank hub. Turn crank. Viola!
Old Nov 5, 2003 | 10:09 AM
mongse_1's Avatar
If you've got the motor out of the car, use a flywheel wrench. Otherwise, the socket in the crank snout works well too.
Old Nov 5, 2003 | 11:11 AM
Brandon 95 Z28's Avatar
Make sure its in neutral too , before turning the crank bolt.
Old Nov 5, 2003 | 11:25 AM
94 CAMRO Z28's Avatar
Good point I made this mistake when doing my cam swap! Was like man this engine is hard to turn over. Then it hit me! Duh! Damn im an idiot!
Aaron
Old Nov 5, 2003 | 11:46 AM
Fastbird93's Avatar
Unless you're trying to break the balancer bolts loose!! I learned the hard way. Doh!
Old Nov 5, 2003 | 11:48 AM
nitropatch's Avatar
you dont need to put it in neutral when i pulled my motor and put it back in and had to turnt he crank it wasnt in neutral and it was easy, not hard to turn it but maybe its just my car i dont know, but thats how you do it.
Old Nov 5, 2003 | 11:51 AM
RallyRed701/2's Avatar
Aaron
does this apply to the autos or just yall 6spds???
Old Nov 5, 2003 | 12:17 PM
I would assume 6spds since an auto can sit in park with the engine running. A 6spd without the clutch in is trying to turn the wheels.
Aaron
Old Nov 5, 2003 | 12:26 PM
BitCypher's Avatar
Remove the spark plugs and it'll be much easier to turn the crank.
Old Nov 5, 2003 | 12:34 PM
Fastbird93's Avatar
Touche' Forgot about that!
Old Nov 5, 2003 | 02:47 PM
BUBBA's Avatar
Pull the coil wire, hook up cheapy remote start button, neutral or park, parking brake set.
Bump starter to get your valves in proper position.
Why get all dirty and skinned up? JMHO
Old Nov 5, 2003 | 04:59 PM
96 WS6's Avatar
I was thinking of taking the spark plugs out but damn that would be a biotch... damn SLP shorties. How do you put the socket in the middle of the crank? You are talking about using the bolt?? That will strip the threads very easily with a breaker bar. The compression is whats really killin it. Just to get the timing chain dots to align I had to put the car in gear and rock it back and forth until they aligned...
Old Nov 6, 2003 | 06:33 AM
Mtrhds94Z's Avatar
Crank hub bolt is 75 ft lb.
It shouldn't take near that much to turn the engine over, even with plugs in?
Old Nov 6, 2003 | 08:00 AM
If using any bolts on the hub or pulley, just remember to go slowly. When you encounter resistance from compression, pause and the compression will bleed off. Then, it gets easier to turn again.
HectorM52
Jul 30, 2017 11:46 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
formula79
26
Aug 5, 2002 12:21 PM
newbielt1
Apr 8, 2002 06:35 PM
