Whats the redline on a 96 z28?
Old Jun 11, 2003 | 01:35 PM
Blue96z28's Avatar
I hear people talking of redline at 5700 or 5800, however, my car is stock pcm/tranny and it will shift(if I floor it) at 6000 every time.....no matter what, also if i hold it in gear manually with it on the floor and shift at 5500, it will hold it out until 6000 and then shift, my rev limiter is a 6200 and will kick in if i dont shift at 6k, is this normal????
Old Jun 11, 2003 | 01:39 PM
IrocManiac's Avatar
it should be 5700 or 5800 your tachometer could be off a little or the previous owner could have pushed up the limiter a little.
Old Jun 11, 2003 | 01:51 PM
Blue96z28's Avatar
is there any way to find out what he did(i.e. anything to check for, loose screws on computer or anything)??? i was wondering if anything is done to it, becuase it seems to run better than my friends auto z's?
Old Jun 11, 2003 | 01:54 PM
madwolf's Avatar
Rev limiter on the 96 is exactly 5886 RPM for the first gear and 5805 rpm for the rest.
Stock tachs are off by about 2-300 rpm on our cars, so it may seem as the limit is at 6200.
Old Jun 11, 2003 | 02:02 PM
Blue96z28's Avatar
well then that sounds about right, also i meant that it shifts a 6, which makes perfect since according to your explanation, i was talking about the limiter kicking in at 6200, thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
bossco
Nov 29, 2014 10:18 AM
redz_02
Jul 24, 2002 09:42 AM
