What's a good "base" before starting to mod?
Old Apr 26, 2004 | 06:59 PM
kevinCHOPTICON's Avatar
I have a 94 z with 130,000 miles. Yes she's old, but I want to bring her back to the strength of the day she rolled off the show room floor. I want to have a good base though before I just jump into exhaust/money mods. Here is what I'm thinking so far.
"Complete" Tune up (fluids, plugs, wires, filters, o2's)
TB Bypass
Ram Air Scoop
IAT Sensor
LT4 KM
160* Thermostat
Any other mods like this that don't really add much power but will improve drivability and give me a good base to start modding?
Old Apr 26, 2004 | 07:03 PM
GreenDemon's Avatar
A manual fan switch would be good unless you plan on doing programming, or else the 160 thermo will only help at higher speeds when air is being forced through the radiator.
Old Apr 26, 2004 | 08:09 PM
LT4orbust's Avatar
timing chain and gears, probably wore a bit putting your cam timing off, might as well put a good cam and lifters well your at it,if your going to run it hard i would also put new rod bearing in it
rideordie
Nov 5, 2019 04:52 PM
Noenav
Mar 1, 2019 07:38 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
