which pushrods do i have/need?
Old Apr 26, 2004 | 08:01 PM
fstenuf's Avatar
i busted a spring on my 210cc AFR heads, and was wondering how to tell which pushrods i need since the one might be bent? i was looking on afr's site and they said one of these 4 would work but idk which one? do they choose by cam size or what? idk what the "+.100" is either could someone fill me in on what that means and which ones you think i might need thanks for the help
AFR Push Rods, 5/16”, +.100” Long, Set of 16 6601
AFR Push Rods, 5/16”, +.200” Long, Set of 16 6602
AFR Push Rods, 5/16”, +.300” Long, Set of 16 6603
AFR Push Rods, 5/16”, +.400” Long, Set of 16 6604
Old Apr 26, 2004 | 08:13 PM
94formulabz's Avatar
Pushrod length depends on:
deck height
head gasket choice
any milling you had done on the heads
spring and valve installed height
cam lift
rocker ratio
Thats a lot of variables! Thats why the prefered method is to just measure it. check this link out http://www.jimcookperformance.com/Te...7ValvLash.html Maybe you can check your contact patch currently and if its close go from there. If you current ones are correct, pull another rocker and measure one thats not busted.
-brent
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
