whats the diffrence in heads
Old Jan 2, 2009 | 04:32 PM
lt1bowtiefreak's Avatar
i have a 95 lt1 impala SS heads and 96 ta lt1 heads, whats the difference between the two heads? after i got them i noticed that they were a little different, yes i know one set is iron and the other is aluminum and i heard that the impala heads used the same casting as the corvette heads?!?!? but that's just what I've heard and anyone give know?
Old Jan 2, 2009 | 10:51 PM
Bowtie4life's Avatar
I've heard that out of the box stock, that the iron casting flow better, but the aluminum heads are better for porting, I'm not 100% sure on that though.
Old Jan 3, 2009 | 12:44 AM
bombebomb's Avatar
From what I have heard. Iron flows better (better no matter what as long as you are comparing apples to apples)
Aluminum is lighter, and easier to port.
Old Jan 3, 2009 | 08:27 AM
96capricemgr's Avatar
The irons have a bigger chamber(62-64cc) and pressed studs. I think it would be interesting to see folks try them for boost builds but almost nobody does.
The iron heads are not Impala specific either, they were used on the Roadmaster, Fleetwood and LT1 Caprice as well.
Old Jan 5, 2009 | 02:51 PM
shaguar_Red's Avatar
I was wondering the same thing. My 1996 Formula engine came with iron heads cuz the guy I bought it from was going to use it for a nitrus build. He decided to go with an LS1 so I bought the engine from him. I have a set of stock 1996 Aluminum heads, but I dont know if it would be worth the hassel of swapping them out.
Old Jan 5, 2009 | 05:07 PM
bombebomb's Avatar
Weight reduction if you did swap.
Old Jan 5, 2009 | 09:22 PM
In addition to the weight savings, the heat transfer characteristics of aluminum generally allow the engine to operate with a higher compression ratio and more ignition advance.
Old Jan 6, 2009 | 03:25 PM
all my behives, 1.6 rockers, pushrods etc will swap right over?
Old Jan 6, 2009 | 10:26 PM
Malice 1's Avatar
yes. I have a iron heads on my LT1 camaro. THe only LT1 f-bod parts you can't use are rocker studs.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
