Whats the difference in the RR Studs
Old Nov 10, 2005 | 09:23 PM
93 4mula's Avatar
Thunder racing has ARP Rocker arm studs and then they have the ARP pro series rocker arm studs, whats the difference and benefits?
Old Nov 10, 2005 | 11:17 PM
MyShibbyZ28's Avatar
Re: Whats the difference in the RR Studs
What did it say? It might have to do with the material it is made out of. Might be a stronger metal. But then again it could be the exact same metal and they could be adding the "pro".
Old Nov 11, 2005 | 12:28 AM
DavesLT1's Avatar
from their description on Jegs: Exact length ARP rocker arm studs are straight and true to provide positive seating. 170,000 psi tensile strength (High Performance),190,000 psi (Pro-series). Not to be used with OEM-style self-locking nuts.
so the pro series are a little stronger, by about 20,000 lbs on tensile strength.
Old Nov 11, 2005 | 05:16 PM
93 4mula's Avatar
Well im building a 383 with a 250/300 shot...Im using the pro mag 1.6's they have those poly locks or whatever you call them. So which would yall recommend running? Heres the link to them.
http://thunderracing.com/catalog/?ac...vid=4&pcid=221
Old Nov 11, 2005 | 06:45 PM
SStrokerAce's Avatar
I don't know what difference in price Thunder has them for but for me the $10 price difference, there is a lot to be gained for that amount of money. The stud setup is already a weak link, a ARP Pro Series 7/16 stud just makes sense and I always recomend that over going another weaker route.
Bret
Old Nov 11, 2005 | 07:14 PM
93 4mula's Avatar
I have brand new 3/8 pro mags so I will have to get the 3/8 stud because I dont want to sell my promags and loose money on those since they are brand new. But you recommend running the 3/8 pro series? Theres nothing specials needed to run those?
Bret
Quickss96
Jan 29, 2016 05:56 PM
bunker
Aug 21, 2015 10:21 AM
whitehooptie
Aug 10, 2015 07:02 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
