whats the best way 2 remove a lt1 motor in a 94 camaro
Old Mar 11, 2007 | 09:44 PM
  #16
FlamingChicken's Avatar
Im sure there is a reason, but why cant you just leave the wheels on and use a jack for the tranny to roll it out? is it too much weight in the middle without support or will it just drag the pan?
Old Mar 11, 2007 | 09:49 PM
  #17
wrd1972's Avatar
You can leave the wheels on but that means you have to raise the car higher to get everything out. If you are doing this on jackstands, you will not be able to leave the wheels on.
Wheels being off gets the K-member closer to the ground.
  #18
Dave89IROC's Avatar
I have done this
you need to put a block of wood between the lower control arm and the k member(keeps the crossmember high), and use a strap to keep the tops of the shocks from splaying out, but it works fine
hardest part is getting the last bolts out with the wheels on, I ended up setting the whole thing on jack stands, then lowering it off them once the body was out of the way
I'll see if i have a pic from one I did like this
EDIT
here you go
and you can just barely see a piece of wood poking out on the right side there
Old Mar 11, 2007 | 09:55 PM
  #19
Dave89IROC's Avatar
agreed, helps if you have access to a hoist
Old Mar 11, 2007 | 11:03 PM
  #20
95Blackhawk's Avatar
Take out from bottom.
Old Mar 12, 2007 | 09:09 AM
  #21
STAYBG87Z's Avatar
is it just me or does putting the jack stands on stacked wood at that angle not look to safe?
Old Mar 12, 2007 | 01:06 PM
  #22
06lingenfelter's Avatar
lol i here that not safe looking at all
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
ChrisFrez
Dec 7, 2014 11:32 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
