whats the best way 2 remove a lt1 motor in a 94 camaro
You can leave the wheels on but that means you have to raise the car higher to get everything out. If you are doing this on jackstands, you will not be able to leave the wheels on.
Wheels being off gets the K-member closer to the ground.
you need to put a block of wood between the lower control arm and the k member(keeps the crossmember high), and use a strap to keep the tops of the shocks from splaying out, but it works fine
hardest part is getting the last bolts out with the wheels on, I ended up setting the whole thing on jack stands, then lowering it off them once the body was out of the way
I'll see if i have a pic from one I did like this
EDIT
here you go
and you can just barely see a piece of wood poking out on the right side there
agreed, helps if you have access to a hoist
Brandon Wittmer
Dec 7, 2014 12:15 PM
ChrisFrez
Dec 7, 2014 11:32 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
