whats the best heads and cam setup im ready to order!
Old Sep 5, 2003 | 02:40 PM
red96z's Avatar
will still be my daily driver but i want alot of power what should i go with at the same time im going to add a 58mm tb i will port the intake get rid of my smog air stuff and get a new program i wonder will all the right stuff how much faster i can be compared to my old time 12.8 at 105.99 thanks ready to order cant wait!
Old Sep 5, 2003 | 03:19 PM
jkipp84's Avatar
You'd probably do better getting exactly what you want by picking up the phone and discussing it with a shop rather than on an internet forum. Check out Combination Motorsports, they seem to have about the best rep.
Old Sep 5, 2003 | 04:19 PM
dobe's Avatar
Advanced induction ported my LT1 heads w/ Ai's "211" cam made 393rwhp on a bad tune
aint got no times yet cause my car is in the body shop but ill have some when i get it out like next week
give Phil a holla
Old Sep 5, 2003 | 07:03 PM
red96z's Avatar
i just figured someone could give me just a little insight cause i was told just do a cam and not the heads cause the lt1s are already aluminum but i know the combo is the best or if i just went with the cam and no heads would there really be that big of a difference if i added a good set of heads with the cam one more thing is combo motorsports the only place i could contact for good advice?
Old Sep 5, 2003 | 07:54 PM
MeanGreen97Z's Avatar
What the hell does having aluminum heads have to do with anything? LT1 heads are ****! Get a good port job and a cam and the car should light up. Give Llyod Elliot a call and spec out a good cam after you get the heads back. NEVER get a cam first. You want to make the most with your setup and by choosing your cam last you will be able to make the most power more efficently. Heads by Lloyd are going to run you about 500-600 after valve job and machine work. Get a good custom cam ground for under 300 and you should be whipping those little LS1 boys up and down the street for thousands less than they paid!
Old Sep 5, 2003 | 08:52 PM
Camaro_Maniac63's Avatar
Best heads + cam combo depends on the kind of money you are willing to spend. If you have around $7000 lying around, go get the 32Valve Arao heads + a custom grind cam. If you have around $1500, try Lloyd Elliott + custom cam. And if you have somewhere in between those, Advanced Induction + custom cam would be my recommandation to you.
www.araoengineering.com
www.advancedinduction.com
I don't think Lloyd has a website yet. Good luck.
Also, keep in mind that it is not about individual parts, it is all about the combination of the parts and how well they work together.
Old Sep 5, 2003 | 09:58 PM
96 TA's Avatar
give this site a try www.combinationmotorsports.com
DirtyDaveW
Dec 1, 2016 05:37 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
