What's the average life of a lt-1 fuel pump?
Thanks for the replies. I've seen people upgrade their fuel lines, 6&8 AN to 8&10 AN, I believe? Is this necessary on an engine that will never really go above 500Hp? Also, AFPR, I've read that they are wasted money, because the CPU will reset the fuel pressure after the first pass? Thanks.
Originally posted by Newbie97
What kills the fuel pumps is heat. What produces heat is running the car low on gas. Keep your tank full and it should last you a long time.
#2 moisture causing the pump to seize (long winter w/water in the gas)
#3 worn motor brushes
#4 burnt wiring connection (common on LT1 pumps)
#5 running the pump dry
A top 10 list is more exciting but we could only come up with 5
stockssn2o
May 25, 2015 08:54 AM
