What are your thoughts on this setup?
Old Feb 14, 2010 | 02:13 AM
madhatter's Avatar
Manley 5.7 H beam rods w/2000 bolts
Probe 383 flat top piston 12336-40
Scatt 9000 383 crank 9-103750L
Double roller timing set-005
CB663HN rod bearings
MS909H+001 main bearings
Plasmamoly ring set R8902+40
Felpro gasket set 260-1650
HA2148 hydraulic lifters
CH8 durabond cam bearing set
M55HV oil pump
EPW 1pc 80 wall moly pushrods
Pioneer oil pump stud kit
Milodon 30909 oil pan
Milodon pickup
LT1 stock casting heads
Intake Max 268 @ 600
Exhaust Max 201 @ 600
2.02/1.60 valves
Comp 7/16" Ultra 1.6 NSA RR
ARP 7/16" Studs
Dual Springs
LT1 stock intake
Light porting
58mm TB
42 lb SVOs
Lunati Voodoo cam 60123
Advertised Duration (Int/Exh): 294/302
Duration @ .050 (Int/Exh): 243/251
Gross Valve Lift (Int/Exh): .560/.565
LSA/ICL: 110/106
RPM Range: 2800-6400
Customer of mine just had this motor built at a shop here in town. I know the heads are choking the cam and cubes, but ran out of money for new heads. TFS are definitely in the near future. Any thoughts or suggestions?
Old Feb 14, 2010 | 08:26 AM
96capricemgr's Avatar
That is a cast crank, WEAKER than stock.
To make valves that size work right you need to replace the seats, BIG waste of money as 2.00/1.56 fits the stock seats right and are capable of big power. For most builds PROPERLY ported stock castings are the right choice even on many track only cars, don't dismiss them.
Lunati's cam card seems not to be LT1 specific because with a LT1 intake a cam 10degrees smaller will make power to 7000rpms easily.
I would call this a pretty typical build, open a catalog and start ordering INSTEAD of doing research on what actually works.
That is why so many stroker cars are slower than the stock shortblock cars that have owners capable of research.
Old Feb 14, 2010 | 11:57 AM
Slick-Z's Avatar
Fo sure you do not need anything bigger than a 52 mm throttle body if your intake manifold is stock. this one will give you plenty of air and will match better to the intake.
Old Feb 14, 2010 | 12:06 PM
Unless he has the intake throttle bores opened up to 58mm......... Many of us have done that.
Old Mar 2, 2010 | 10:45 PM
357LT1's Avatar
With 152k on stock crank and already reused for 1 build, a new crank was in order. Not building a 800-1000hp car so the Scat was more than enough if balance properly as per my research. I saw all the drilling and weight addition Roger at Standard did on it, spent good amount of time on it. Some weights the size of a quarter! As far as valve, once again I'm sure Roger took care of the seats. I didn't want a stroker, we could of kept it .040 over, actually .042 but when wanting to buy a crank and Roger throwing in stroker clearance work for free for being new customer, I said what the heck! Better heads can wait.
Old Mar 2, 2010 | 10:47 PM
357LT1's Avatar
And yes, the intake is ported for 58mm. Has been since last build in 2001.
Old Mar 2, 2010 | 11:18 PM
LearJet's Avatar
You say your sure "Roger" took care of the seats. You got a bill for this work didn't you? You would know for sure if you paid for 16 new seats. I dunno about those lifters, never heard of them. Is it running yet?
Old Mar 3, 2010 | 01:53 AM
RamAir95TA's Avatar
Cast Scat crank, barf. Like Dwayne mentioned, save a buck and pick up a stock crank from somewhere. It will be much more reliable than that cast Scat crap.
M155HV pump, barf. Not only do you likely not even need a HV pump, but the 155s have a weak casting and have been known to break. The MUCH better alternative is the 10554.
Old Mar 3, 2010 | 04:53 AM
maddog05's Avatar
Dwane gave you the right, and complete answer. I'm curious how this car runs at the track?
Old Mar 3, 2010 | 06:11 AM
357LT1's Avatar
When I get back home from Cleveland, I'll check one of the 3 invoice I got back from shop. One of them has all the parts and labor just for the heads. Now remember, list above was all I think was needed to post to show what the setup would look like. Wasn't going to type all parts and pieces along with block and heads labor.
Old Mar 3, 2010 | 06:19 AM
357LT1's Avatar
I disagree, only catalog part I chose was the cam. Everything else was Standard Machine. Only thing I was worried about them building my motor is that he is an OLD school guy and really doesn't do too many LTX and LSX builds. He is well know in the drag circuit in AZ, so needless to say he was a little tentative about 11.1 compression I asked for and using that cam on an a 110 LSA for a street car. Engine not installed yet. Shop was really backed up with work, just got motor back a week ago, now I'm in Cleveland for 3 weeks.
Old Mar 3, 2010 | 09:22 AM
LearJet's Avatar
It's going to be real hard to find a stock crank with the same stroke since he has a 383. There are much better choices than that crank however. If the engines not in the car yet I would change the crank to something forged. I agree with you on the pump. I would just use a stock pump with the white spring.
Old Mar 3, 2010 | 09:44 AM
357LT1's Avatar
Believe me, I had a hard time deciding if I should do a forge crank. At least a week of researching and being undecicive. The more research I found about people running cast in high HP applications, the better I felt. Like I said, assembly balance is HUGE! You think the cast matrial is weaker on an aftermarket piece? As far as pump, once again that was left to the experience engine builder. Believe me guys, I am too wanting this thing to get turned over soon! Hard when you travel all the time.
Old Mar 3, 2010 | 10:03 AM
Nathan S. Parki's Avatar
My thoughts are that is just a waste of money all around.
Old Mar 3, 2010 | 10:10 AM
357LT1's Avatar
LOL! It's cool, just a months salary for me, or my wifes. Take your pick! Having the money to spend is one thing, needing to spend it is another. Thanks for your input.
