What would you do for a good tune up?
Old Nov 6, 2003 | 09:41 AM
Red96Lt1's Avatar
Air filter (I don't need to replace mine yet), O2, Fuel filter, Plugs and wires. What eles would you do?
Old Nov 6, 2003 | 11:46 AM
TMDZ28's Avatar
coil, opti
Old Nov 6, 2003 | 11:50 AM
J96Z's Avatar
Sounds like you about have most stuff covered. I'd say oil, diff oil, dont change the trans fluid unless its dark and/or burnt smelling. Check your belt. Pull the throttle ducting off and clean out your throttle body with some cleaner. I usually hold it open and use a screw driver with a rag doused in cleaner to get all the gunk out. Other people may have more ides on stuff. Hope I helped.
Old Nov 6, 2003 | 12:18 PM
jasons93z's Avatar
Originally posted by TMDZ28
coil, opti
Coil=yes. Opti=NO. There is no reason to go through all the labor if its not broken.
Old Nov 6, 2003 | 08:08 PM
$hawn's Avatar
Dont forget a new pcv valve.
Old Nov 7, 2003 | 09:35 AM
Red96Lt1's Avatar
Ahh, Thanks.
Old Nov 7, 2003 | 10:45 AM
Red96Lt1's Avatar
Is there a reason to replace the coil, I'm guessing that I won't see any power gains. Also, which one do you suggest. I have 154K on the clock.
Old Nov 7, 2003 | 10:50 AM
rpm4lalo's Avatar
Fresh coolant.
And be sure to check fluid levels, such as power steering, brake, and hydraulic for the t56.
DirtyDaveW
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
