what would happen?
Old Jan 8, 2005 | 08:35 PM
RMC's Avatar
RMC
what would happen?
What would happen if the aldl wires shorted out somewhere in the wiring harness?
I'm getting a really weird electrical problem where the computer resets and sometimes that fans will kick on. It's not in the ignition wires as I've checked all through those. It seems like when I wiggle the aldl wires is when it happens. Any idea? I'd hate to sit and unravel all the electrical tape just to find out that the aldl shorted out wouldn't even cause that problem.
Old Jan 8, 2005 | 11:55 PM
ejfagala's Avatar
Re: what would happen?
The fans kicking on does sound like you have some sort of ECM problem. An intermitant short on the LADL plug could definatly cause some crazy stuff to happen for one thing it could cause it to think it was in diagnostics mode all of the time. Have you tried disconecting the ECM and running a continuity check yet?
Old Jan 9, 2005 | 12:11 AM
RMC's Avatar
RMC
No, I'm dying for help though. I have to get this working ASAP. I don't know which wire is where at the computer end to check. That would be very valuable info though. It's definately a short somewhere and it's involving the computer too because it's only computer controlled events that are happening. Mostly it's just the computer resetting and the injectors and pump priming. I've been at it all night so hopefully you can get back to me soon so that I have a shot at fixing it tomrw.
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
