What type of fluid is being re-routed during throttle body bypass mod?
Old Jan 31, 2003 | 09:55 PM
94z28jbw's Avatar
Question What type of fluid is being re-routed during throttle body bypass mod?
Old Jan 31, 2003 | 09:57 PM
white97T/A's Avatar
coolant
Old Jan 31, 2003 | 09:59 PM
94z28jbw's Avatar
Thumbs up
Originally posted by white97T/A
coolant
Thanks white97T/A
Old Jan 31, 2003 | 10:05 PM
94z28jbw's Avatar
Question Just wondering because...
Just wondering because when I installed my new throttle-body top plate [from MBA], I noticed some oil residue in there. Is this anyhthing to be worried about?
Old Jan 31, 2003 | 10:30 PM
Buttercup's Avatar
No, that oil residue is normal. The PCV system allows some oil fumes into the TB.
Old Jan 31, 2003 | 10:31 PM
Pretty much normal for there to be some oil in there. It is drawn in from the passenger side valve cover.
Old Jan 31, 2003 | 10:43 PM
notstock4long's Avatar
What is the advantage of the bypass, I never really understood it?
Old Jan 31, 2003 | 10:47 PM
Buttercup's Avatar
It helps keep intake charges cooler. Engine coolant is not cool at all, routing it through the TB heats the incoming air charge.
Old Jan 31, 2003 | 11:46 PM
94z28jbw's Avatar
Question Well...
So you do mean coolant as in, antifreeze/water mix, right? I just don't understand why the coolant and the oil aren't mixing in there;
or are they seperated within the TB?
Old Jan 31, 2003 | 11:57 PM
Z28ROC's Avatar
Yes
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
David Dorris
Jan 17, 2015 08:10 PM
RedLineRev
Jan 23, 2003 03:51 PM
