What tires & size should I run?
Since I put in the vigilante and put 3.23's back in the car I can't get much traction.
Should I run ET streets or get some slicks? I'm
building a new engine and wanting to put Nitrous on this one but I've got to get the car to hook.
What size ,type should I get and where's the best place to get them?
Re: What tires & size should I run?
As far as size, there are a lot of options. The most cost effective is to get a set of stock 16x8" rims and use a 26x11.5x16" tire. These should be good for 60' times in the 1.5 second range with sotck suspension if you have enough hp. They will fit with no modifications to the fenders or wheel wells.
Rich Krause
Which drive shaft would I need?
I wouldn't spray Nitrous out of the hole on my 10 bolt.
Rich Krause
Most likely the rear end will break before the DS. If you plan a stout motor and nitrous, you need an aftermarket steel DS to go with the rear end you will need! Denny's "nitrous ready" is an excellent shaft at a fair price. Mark Williams makes an excellent shaft, but quite pricey.
Rich Krause
Rich Krause
bossco
Nov 29, 2014 10:18 AM
