What TEMP should fan kick in at
Old Oct 1, 2004 | 08:21 PM
budvol's Avatar
I dont think mines workin... what should I check?
Old Oct 1, 2004 | 08:28 PM
teke184's Avatar
Re: What TEMP should fan kick in at
220 is the first fan i think
they running a 12v lead to each fan to see if the motors are burned out.
Old Oct 1, 2004 | 08:36 PM
budvol's Avatar
My overheat light comes on at about 190 or so
Old Oct 1, 2004 | 08:38 PM
97zSC's Avatar
i thought the second fan kicked in at 210
budvol's Avatar
Or at about the 4th mark what ever temp that is
Old Oct 2, 2004 | 09:57 PM
Stock programming turns the first fan on at 226degF and the 2nd fan on at 235degF. In the later model, those settings are used for low and high speeds, rather than individual fans.
You mean the "check gauges" light? The gauge and the idiot light are driven off the sensor in the drivers side head. The engine fans are controlled by the PCM, which uses the sensor in the water pump housing. Might have a problem with one of the sensors.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Zuvell
May 15, 2015 08:18 PM
Biggiebound
Apr 23, 2015 08:50 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
