What starter for new 383 daily driver with 11:1 ?
Old Oct 19, 2005 | 06:01 PM
rawbutt's Avatar
looking for recommendations on starters. mine is the original from 1995 w/ 150K on it and it's not liking my new 383 very much. It's starting to sound tired and slower than it used to. can anybody recommend a good replacement starter that will stand up to the higher compression and last for a long time? also, i have pacesetter LT's, so want to make sure i dont have any clearance issues with the new one because i've already had my share elsewhere!
thanks !!
robert
Old Oct 19, 2005 | 06:15 PM
Mindgame's Avatar
Re: What starter for new 383 daily driver with 11:1 ?
11:1 is no biggie. I'd just go with the LT4 starter from one of the GM parts houses.
-Mindgame
Old Oct 19, 2005 | 06:43 PM
rawbutt's Avatar
Mindgame,
I've read a couple posts about people having clearance issues with the LT4 starter? Should I worry about that? Will I definately have to drop my Y-pipe to install it?
Old Oct 19, 2005 | 07:30 PM
FastZinTennessee's Avatar
My LT4 starter clears Hooker Long Tubes and a Canton Racing oil pan no problem......
Old Oct 19, 2005 | 07:45 PM
BlackScreaminMachine's Avatar
http://www.csr-performance.com/Merch...Category_Code=
I use this starter with my 11.25 to 1 motor, clears everything and saves a TON of weight. GET THIS!
Old Oct 19, 2005 | 10:24 PM
I got a CVR ProTorque starter from JEG's for $150. Spins the 381 fine, and the mount rotates to several positions, so you can move the starter away from headers, etc. I think JEG's now sells that item under their own name as the JEG's ProTorque starter.
You really don't need anything more powerful than the stock starter, but I seem to have toasted 2 of the stockers with header heat. The CVR has been going strong for 5 years now.
http://cjcfo.fbody.com/members/injun.../DCP03670a.jpg
Old Oct 20, 2005 | 07:20 AM
rawbutt's Avatar
thanks for the ideas guys....
injuneer....i'm assuming this is the new "jegs" version of the CVR you are referring to that you have?
http://www.jegs.com/webapp/wcs/store...0689&langId=-1
the pricetag is appealing to me as well as the fact that you burned two stockers up, yet that one has been working for 5 years. i too believe my headers might be pushing my stocker to its grave. couple questions...with the one you have, do you think i would have any clearance issues during installlation? I have Pacesetter LT's with matching Pacesetter Y-pipe. also, do you think the starter heat shields are worth considering?
http://store.summitracing.com/partde...=KeywordSearch
thanks again!
Old Oct 20, 2005 | 10:30 AM
Will84's Avatar
I've never had a problem with the stock starter. I'm also running an 11:1 383.
Old Oct 20, 2005 | 10:57 AM
CANTONRACER's Avatar
I had no choice with my current setup to find a more compact starter because after my Kook's stepped headers I had no choice.
Summit Racing has a good selection of starters on display and I bought the smallest one they had THIS ONE
What surprised me was that it weighs 6 lbs and it only weighed a little over 2 lbs less than my stock starter.
Even with this very small starter...it barely fits.
Old Oct 20, 2005 | 11:15 AM
With my JEt Hot LT's the smallest starter csr makes fits fine, the next step up bearly fits, also the csr starter is like 6 pounds as well. i am very happy with their products.
Old Oct 20, 2005 | 11:45 AM
rawbutt's Avatar
well, the thing is, i'm still using my stock starter now and it obviously fits, right? so i guess as long as the replacement is the size of the stock one or smaller, i would ok?
which is the smallest CSR of this bunch that 'BlackScreamingMachine' is talking about?
CSR starters at Jeg's
Old Oct 20, 2005 | 01:25 PM
Looks just like it. The JEGs/CVR starter is not light-weight at all. It weighs maybe a pound more than the stocker, even though its smaller. I guess its the extra windings and the gear reduction.
Old Oct 20, 2005 | 01:29 PM
rawbutt's Avatar
Injuneer.....
Cool.....what about the heat shield stuff? You mentioned burning a couple stock units up because of header heat. Do you think I should spend $25 and put one on the new unit?
Old Oct 20, 2005 | 02:25 PM
rskrause's Avatar
Moderator
If you have a good stock starter, use it. I see no point in pointless "upgrades". I guess that's redundant, but you know what I mean. If you need a new starter, I have used Powermaster for years and have never had a problem. They are a little cheaper than the comparable CSR.
Rich
Old Oct 20, 2005 | 02:59 PM
Turbo6's Avatar
I'm running 12.0:1 in my solid roller 383 and my Autozone LT4 starter turns it over fine. It sounds cooler than an LT1 starter too.
