What springs to use for .600 lift?
Old 01-18-2004, 01:51 AM
BottleFedZ28's Avatar
What springs would I need to get to run a .595 lift cam?
I need a part number please.
BottleFedZ28 is offline
Old 01-18-2004, 01:58 AM
97 RedSS's Avatar
Springs in my sig would work..
Cody
97 RedSS is offline
Old 01-18-2004, 06:37 AM
Don 97 SS's Avatar
First give consideration to the spring recommended by the cam manufacturer. Don't immediately assume there is a better spring out there. If you have your heads modified, then you have more choices. There are many variables to consider in finding the right spring, handling .600 lift is just one.
I have the same springs as Cody mentioned above. I hear good reports about them and they have worked well for me.
Don 97 SS is offline
Old 01-18-2004, 08:30 AM
Moderator
rskrause's Avatar
What are the cam specs and how high do you plan to rev it? Do you need a stock diameter spring?
Rich Krause
rskrause is offline
Old 01-18-2004, 11:20 AM
XE 230/236 cam with 1.7 rockers. Stock diameter springs needed. Revving to 6700.
Building a 383 as we speak.
Old 01-19-2004, 11:04 AM
Don 97 SS's Avatar
You'll want a stout dual spring. The Crane 99893 has a good reputation and fits in the oem LT1 heads. It will handle the lift on your cam just fine and provide good set pressure for high revs when installed at the proper height.
Comp makes pretty good stuff, so consider their spring recommendation. CC has a great informative website.
Old 01-19-2004, 11:57 AM
FacelessZ's Avatar
The 1.7 rockers with that cam probably isn't that smart...
How high are your valve covers going to be?
FacelessZ is offline
DirtyDaveW
03-15-2015 07:01 PM
MadMav
02-06-2015 11:02 PM
Red_94Formula
01-22-2015 12:17 AM
Quick Reply: What springs to use for .600 lift?
