What Spark Plugs?
Old Dec 2, 2008 | 11:14 PM
MTBSully's Avatar
What Spark Plugs?
For a 383 11:1 CR? I usually use TR-55's on my older Fbods but was thinking of going with TR6's since this new car has the higher CR. Opinions? Also, what should i gap them at? Thanks guys
Old Dec 3, 2008 | 12:43 AM
bombebomb's Avatar
Hmm, I never even thought about switching out my spark plugs on the new engine. Ill be keeping track of this thread. At the moment im running TR-55's with .050 gap, as recommended on the stock engine.
Old Dec 3, 2008 | 03:22 PM
MadMike 97 Z28's Avatar
I would still run the tr55's if its N/A and gap them at .045 or maybe even .040 but if your running spray then I would deffinitely go with the tr6's.
Old Dec 4, 2008 | 07:55 AM
MTBSully's Avatar
thanks mike. Any other opinions?
Old Dec 5, 2008 | 11:13 PM
marshall93z's Avatar
I'm running TR6s in mine.
Old Dec 6, 2008 | 11:15 AM
Spark plug requirement is dictated by engine operating conditions. Bump your HP up significantly, and you usually (but not always) need a colder plug to keep from burning the electrodes up, or promoting pre-ignition. If you are running the TR55's, check the gap after a couple thousand miles and see if it has opened up. If it has, you need a colder plug. You can also get a reading from the condition of the insulator around the center electrode that will indicate if you are running the correct heat range. Go too cold and you are going to carbon up the plugs.
I've had good luck with the TR6's with nitrous on a stock/bolt-on setup, and with the stroker and not running nitrous, Autolite 104's. There's a bit of a debate whether the 104's are 1/2- or a full-step colder than stock, but they work for me. With a small shot of nitrous I drop down to the 103's.
Old Dec 6, 2008 | 05:12 PM
camaro1fastz28's Avatar
i got a 12:1 355 and i am running tr6 gaped at .035
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
