What size vacuum cap.
Old Nov 28, 2005 | 03:13 PM
LT1 POWR's Avatar
Wthat size vacuum cap is needed for the vacuum lines for EGR and AIR removal. And what should i use to plug the hole in the CAI.
Old Nov 29, 2005 | 11:17 AM
LT1 POWR's Avatar
Re: What size vacuum cap.
Ok. I found out that i should use a 5/8" vacuum cap for the AIR system, and a M22 1.5 drain plugs for the headers. Is it a 5/8" vacuum cap for the EGR system also. And what should i use to cap off the CAI.
Old Nov 29, 2005 | 03:56 PM
The 5/8" vacuum cap is for the AIR hose connection on your CAI.
The vacuum lines for the AIR (assuming you had the AIR recall done, and they added the vacuum connection) and EGR vacuum solenoid come off the nipples on the drivers side of the intake manifold.... just measure them and get something close, or take the old hose to the parts store with you and see what matches.... maybe 1/8"???? It isn't all that critical, as long as it seals tight.
Old Nov 30, 2005 | 08:15 AM
JasonK94Z's Avatar
The 5/8" vacuum cap can also be found in the "help" section at autozone or o'reilly's. Its a "bypass cap". I couldn't find one that big with the regular vacuum caps, then I discovered the "help" brand section.
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
350350
14
Aug 11, 2015 12:03 PM
cjamen
Jul 27, 2015 12:48 PM
whitehooptie
Jul 12, 2015 06:10 PM
