Vacuum Line Question
Old Jul 27, 2015 | 10:12 AM
cjamen's Avatar
Can you help me identify where the vacuum line I have capped off (see red cap on vacuum line in pic) should go? Also, should a vacuum line be plugged into one of the 2 ends of the plug you see in this pic? I'm not sure what that plug is but I'm assuming it's some kind of valve. This picture is in behind the driver front quarter panel. Here's a link to the picture, taken from under the car.
GEDC0215.jpg Photo by cjamen | Photobucket
Old Jul 27, 2015 | 10:19 AM
Re: Vacuum Line Question
There are two possibilities, and it's pretty hard to pin down without basic info about the car - year and engine for example:
https://www.camaroz28.com/forums/lt1...nature-879835/
Assuming it's an LT1, one possibility is a solenoid in the AIR system, but that is highly dependant on year of the car, and whether the AIR pump recall was done on it.
http://shbox.com/1/air_pump_recall.jpg
Old Jul 27, 2015 | 10:25 AM
cjamen's Avatar
My Bad - (blushing and feeling silly for not providing any details)
It's a '94 Camaro 3.4L. The picture and the parts are located in the same area as the air pump is located.
The only reason I'm searching for a vacuum problem is because when you accelerate, the AC quits blowing throw the vents and moves to the defrost but once the RPMs lower again, it continues to blow through the vents. So, I'm figuring that I've got a problem with weak vacuum.
Old Jul 27, 2015 | 10:27 AM
>>>> 4th Gen LT1 F-body Tech Articles
Old Jul 27, 2015 | 11:04 AM
cjamen's Avatar
Thanks for sharing the link. I'll be sure to use that to identify the vacuum issue with the AC vents.
With regards to the vacuum line that I capped off (see red cap in pic), do you know where this should be routed to or should it be open? I can tell you that it does pull vacuum.
Old Jul 27, 2015 | 12:48 PM
Don't know. Not familiar with the V6 stuff.
Feffman
Oct 9, 2015 05:42 AM
Deadbolt24
Jan 19, 2015 01:29 PM
pologreen97z
Dec 2, 2014 10:42 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
