What size injectors?
Old Aug 1, 2003 | 10:08 AM
95Z06/Z28's Avatar
What size are the stock injectors on a 95 Z28?? I have added slp y-pipe, cat removed, flowmaster, 3.73 gears, ported mass air, k&n fipk, 150 shot NOS brand dry kit, madZ28 programmed computer. Underdrive pulleys. What size injectors should i go with to accomodate the dry kit and added mods? And what are some good brands and places to get them for descent prices?
Old Aug 1, 2003 | 10:13 AM
Camaro_Maniac63's Avatar
I believe stock 95 z28s came with 24lb/hr injectors. You might want to upgrade to 30lb/hr ones instead. I don't really know where to get them from though, actually I am looking for 30#s myself. Good luck.
Old Aug 1, 2003 | 12:34 PM
MadMaxz28's Avatar
30's will work with your bolt on setup. i just bought a set of Ford 30# injectors off ebay for $140shipped but if you plan on heads/cam or stroker id go with 36'ers
Old Aug 1, 2003 | 04:24 PM
If your "NOS dry kit" is the 5176, you want to stay with the 24# injectors, with your otherwise limited mods. The 5176 kit raises the fuel pressure to 85-90psi when you spray, to get the added fuel. You don't need a bigger injector. The NOS jetting recommendations are based on the stock 24's. What you should consider with the dry kit is changing you 24# stock injectors out for 24# pintle style (SVO, Ford, Bosch, etc.) injectors. The stock ball and seat injectors do not like to operate at 90psi, and can lock up on you.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
