What should the IAC read?
Old Feb 13, 2005 | 11:03 PM
Got-LT1's Avatar
My brother has a 94 Z28 with some idle problems, I got him to send me a datalog of his engine and his IAC numbers all over the place. They start at 156 and then are from 73 to 100+. Is this normal?
Old Feb 13, 2005 | 11:06 PM
ibanez6rg's Avatar
Re: What should the IAC read?
I think around 32.
Old Feb 13, 2005 | 11:24 PM
Lt1t56's Avatar
When engine is at operating temperature it should read between 20-40
Old Feb 13, 2005 | 11:56 PM
turbo_Z's Avatar
If the car has heads/cam or some power adder then the IAC counts could go that high.
Old Feb 14, 2005 | 12:01 AM
Got-LT1's Avatar
It has a cam, CC304 if I recall, but stock heads
Old Feb 14, 2005 | 04:48 AM
slopokrodrigez's Avatar
He has a vacuum leak
Old Feb 14, 2005 | 11:44 AM
Why would a vacuum leak cause the IAC to open up, and provide even more air?
Old Feb 14, 2005 | 02:06 PM
Red-LT1's Avatar
Yes it's a CC304 cam, with stock heads. If anyone wants to see the log file, here it is.
Old Feb 14, 2005 | 07:38 PM
Red-LT1's Avatar
Anyone else? Also, the problem is only in gear, not neutral or park.
Other problems:
Bad gas milage
Sometimes a light throttle stuble only in 4th gear around 45-50mph.
Occasional backfiring at higher RPMs, espically when cold.
The plugs and wires are pretty new, and O2 sensors were just put in.
Old Feb 16, 2005 | 07:09 PM
We all got to take our lumps especially when we have a brain fart. He said higher but I saw lower.
What you could do is remove the IAC and see if it is actually moving when commanded by the PCM. I use a pencil with one of those push on replacement erasers trimmed to fit in the IAC pintle hole. If the PCM is responding to differing demands to change the idle, it will move the IAC pintle in response to either slightly restricting or unrestricting the IAC passage with the pencil eraser. This will allow you test the entire IAC system.
HectorM52
Jul 30, 2017 11:46 AM
Zuvell
May 15, 2015 08:18 PM
lt1matt
Mar 21, 2015 07:35 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
